cross-referencing
I am new to Inkdrop and I love it.
Sorry for my ignorance! I was wondering how can I refer to a note in another note.
There must be some syntax for that. Please help.
Regards,
Tamoghna
Regards,
Tamoghna
Hi Tamoghna,
Thank you for the question.
You can copy an internal note link from the context menu like so:
You should get a code in clipboard something like:
[Set up another CouchDB server](inkdrop://note/YzY7nZZcn)
Thank you very much!!
This works. Of course!!
By the way, I also like the structure of this forum. Would you please write sometime about it on your blog? Please.
Also you should check out the great wikilinks plugin @Ryan_McQuen wrote and I helped with which works more like Obsidian so you don’t have to copy the links manually; it is the “one neat trick” Takuya doesn’t want you to know.
This one:
https://my.inkdrop.app/plugins/wiki_links
@ebigram did the hard stuff.
