When I paste markdown text, Inkdrop insert some symbol charactor.
I’d like to disable it but couldn’t figure out in settings.
Is there a something way?
It could be related to the html to markdown conversion. You can try pasting it as plain text by pressing ctrl+alt+shift+V in inkdrop. If this doesnt do what you expect, could you share the markdown text that you copied as it is not really clear which symbols get added by inkdrop and which are from the source?
@Lukas Plain text copy working fine. Thak you ![]()
