Hi, there
I’m using my emacs-keybindings plugin.
This plugin binds ctrl-k to emacs-mode:kill-line command and it used to work well.
But from a certain inkdrop version, the command has been executed with some delay.
This is probably due to default key bindings which have multi-keystroke commands like ‘ctrl+k left’.
So I added following settings to my keymap.cson, but they changed nothing.
'.CodeMirror textarea':
'ctrl-k left': false
'ctrl-k up': false
'.mde-preview':
'ctrl-k up': false
'.sidebar-menu':
'ctrl-k right': false
'.sidebar-workspace-menu':
'.note-list-bar':
I want to execute the command immediately.
How can I disable multi-keystroke keybiindings completely?
March 25, 2021, 6:00am
Hi Shunichi,
Thank you for the question.
You are right, those keybindings cause the delay for the emacs keymap.
You have to remove keybindings like so:
var b = inkdrop.keymaps.keyBindings
inkdrop.keymaps.keyBindings = b.filter(a => !a.keystrokes.startsWith('ctrl-k '))
I found myself not using ctrl-k arrowkey shortcuts, so I’ll consider removing them.
Thank you for quick answer!
I’ll try it.
May 5, 2021, 1:51am
Fixed in v5.3.0🎉 Thanks again for the report. Credited here:
How can I unbind the current core:toggle-bulleted-list keymap which conflicts with my workflow key and reassign it to ctrl-cmd-b?
February 6, 2026, 1:11am
6
@Bundit_Jianpinitnan You can unbind a keymap and reassign it with this:
"body": {
"cmd-shift-l": "unset!",
"ctrl-cmd-b": "core:toggle-bulleted-list",
For more information:
