In preview, the container of code snippets are scrollable.
However, export to pdf, the code is truncated
I have to to this:
1> export to html
2> modify html content to below
.mde-preview pre > code {
padding: 0;
margin: 0;
font-size: 100%;
**word-break: break-all;**
** white-space: pre-wrap;**
background: transparent !important;
border: 0;
3> use chrome, convert html to pdf
Can we have an option to do this automatically? Thanks.
April 16, 2021, 8:54am
Hi Gogdizzy,
Thank you for the report.
That’s weird. The behavior you’d expect should work fine in exported pdfs.
I confirmed that word-wrapping works well:
So, I can’t reproduce the issue. What is your environment?
OS: macOS Mojave 10.14.6
InkDrop ver: 5.2.1
And with plugins:
Maybe any plugin conflict?
I closed all plugins but ‘export-print’, and export to pdf still not ok,result is
April 17, 2021, 8:04am
5
Thanks for the information.
Do you use github-markdown (built-in) for preview theme?
It already has a CSS for print like so:
@media print {
.mde-preview table {
overflow: hidden;
word-break: break-word;
word-wrap: break-word;
I have run into the same issue, didn’t know that the theme played a role in that. Just checked again and can’t reproduce it.
Currently using:
Dracula Dark UI for UI Theme
Horizon Dark Syntax for Syntax Theme
Dracula Preview for Preview Theme
Don’t remember which themes I used when I ran into that issue. However, can confirm that it also happened on my end.
Thank you.
Yes, the Github-Preview is OK.
I used Colorfi preview before. because i think colorfi is very beautiful.
I followed the doc, copy the css code to “~/Library/Application\ Support/inkdrop/styles.less”
It works.
Now I can use Colorfi preview and export to PDF with wrapping.
April 20, 2021, 3:03am
9
Looks like the style should be built-in to the app itself! I’ll fix it in the next release.
Thanks again for reporting, @anon1398951 and @gogdizzy_dizzygog
May 5, 2021, 1:50am
10
Fixed in v5.3.0🎉 Thanks again for the report.
This seems to be happening again.
App Details:
Version: 5.4.3
I have tried both the Github Preview & Colorfi Preview just to be sure.
October 18, 2021, 6:31am
12
@Anagh_Kumar_Baranwal Thanks for reporting.
That’s weird. I tried to reproduce it but works fine like so:
I don’t know what to say then.
Do you want me to check anything specific? Or give you specific config files?
October 18, 2021, 7:41am
14
Can you give me an example Markdown?
Also, please try disabling other plugins.
