Hangs on MacOS Sonoma when accessing Finder
When opening “Preferences” → “General” → “Open config folder” or “Preferences” → “Keybindings” → “your keymap file”, it tries to access the file in Finder but it hangs.
  • Platform version: Sonoma 14.2.1
  • App Version: 5.6.2
Open “Preferences” → “General” → “Open config folder” or “Preferences” → “Keybindings” → “your keymap file”.
Hi Shun,
This is a known issue in Electron but found a workaround.
Will be fixed in the next release!
It should be fixed in v5.7.0:tada: Thanks for reporting.
