I am still experiencing this issue with the Beta version of the Android app. Anything I can do to help diagnose the issue?
- Platform: Android, Pixel 2
- Platform version: 10
- App Version: 3.6.0 (says the Android applications menu)
@Michael_Kochell
I guess it looks like your environment-dependent issue.
Could you please create a separate topic for the issue?
Do you use Gboard or third-party keyboard?
If possible, please take a screencast to show me the issue.
Hi @craftzdog, thanks for the quick response!
I figured out how to reproduce the issue. I’m using GBoard with glide typing.
Expected:
A space is created after the previous word, and new word is right after the space.
Observed:
The new word crashes into the next word. I really don’t know how else to describe it.
Here’s a video of it occurring. Don’t mind the quality of the recording. https://www.youtube.com/watch?v=hpHs5MylH_k
Thank you for the screencast and detailed explanation.
It looks like a bug and I could reproduce it.
Gboard’s behaviors are quite inconsistent and that makes hard to support.
It will take time to fix, or it might be impossible.
BTW, Inkdrop uses CodeMirror for its editor and its next version is being developed now.
I’d expect it will fix this Gboard problems.
