A last question:
Is there a plugin which adds footnote support? (I tried ipm search footnote
, ipm search multimarkdown
and ipm search pandoc
but didn’t get any results.)
A last question:
Footnote is currently not supported out of the box because it is not compatible with CommonMark.
You can extend the markdown renderer to support it by creating a plugin using the following API:
Thanks.
Looking at the doco it seems possible to add footnote support just via an option to remark.
Yeah, you don’t even have to create a plugin. You can use the init file to change the remark option to enable footnote:
Wow, that’s super cool. Works like a charm.
And an impressive response time, too.
Enjoy~
This is super cool @craftzdog. Thank you
Glad to hear you like it, Erdem!
