Follow note link from editor
Would be awesome if we could click on note links (internal links) from the editor.
Right now I have to enter preview mode and find the link before I can follow it. Seems a bit awkward.
Thank for the amazing software!
Hi mauz,
If you have following markdown:
[label](inkdrop://note:ryeZ-_3GDf)
You can double-click the URL itself to open it.
NOTE: It won’t work if you use with vim plugin.
Currently, double-clicking label part doesn’t support opening links.
I understand it seems way natural to support it, so I will consider to support it.
Hi craftszdog
Ohh, didn’t notice the inkdrop:// URL was actually clickable. This is will work fine for me, thank you for the hint.
But usability wise it could certainly be improved :slight_smile:
