Folders gone
I started the program this morning and all of my folders and files are gone. My name and the gear icon are no longer there either. It opened to a new daily note and everything else is gone.
Write the description of the issue here.
If you got a problem, please check if you got any error in the console log by selecting the menu: Developer -> Toggle Developer Tools.
If you report an issue about a plugin, please check the author of the plugin:
  • If it’s a third-party plugin, report it on the GitHub Issue
  • If it’s an official plugin, report here
  • Make sure you are using the latest version of the plugin. You can update it with ipm update.
  • Platform: (macOS/Windows/Ubuntu/iOS/Android)
  • Platform version: (Mojave/10/16.04)
  • App Version: (4.3.0)
Write the steps for others to reproduce issue here.
Hi Pat,
Thank you for the report.
So, you can’t see any folders, notes, even your name or settings icon. Looks like the whole UI is corrupt for some reason.
I checked the database and your notes are not lost.
As you reported this: Uncaught(in promise), you are using third-party plugins. That might be causing the issue.
Also, it could happen when the app failed to auto-update. Please try reinstalling the latest version from here.
Can you share a screenshot and provide your environment and app version? Please fill in the template.
He said it’s resolved. (@Pat_Smith Please reply on the user forum instead of replying to the notification email directly next time)
Yes, the issue is resolved.
