Failed to save note
“stack”: “not_found: missing\n at Object. (/usr/lib/inkdrop/resources/node_modules/pouchdb/lib/index.js:481:19)\n at Module._compile (node:internal/modules/cjs/loader:1484:14)\n at Module._extensions…js (node:internal/modules/cjs/loader:1564:10)\n at Module.load (node:internal/modules/cjs/loader:1295:32)\n at Module._load (node:internal/modules/cjs/loader:1111:12)\n at c._load (node:electron/js2c/node_init:2:16955)\n at Module.require (node:internal/modules/cjs/loader:1318:19)\n at require (node:internal/modules/helpers:179:18)\n at 4104 (/usr/lib/inkdrop/resources/app.asar/main.js:1:44643)\n at n (/usr/lib/inkdrop/resources/app.asar/main.js:1:123830)”,
“status”: 404,
“name”: “not_found”,
“message”: “missing”,
“error”: true,
“reason”: “missing”,
“docId”: “note:tAze15x5”
Please follow the template
  Hello! 👋
  Thank you for opening an issue on Inkdrop.
  You can post if you encountered a problem, bug, issue, or simply have a question.
  There is also a 3-Minute read, on how to format your issue:
  https://guides.github.com/features/mastering-markdown/
  This template is optional, but it may help us fix your issue faster.
* [ ] I have checked [the troubleshooting](https://docs.inkdrop.app/manual/troubleshooting)
## Bug report
Write the description of the issue here.
If you got a problem, please check if you got any error in the console log by selecting the menu: `Developer -> Toggle Developer Tools`.
If you report an issue about a plugin, please check the author of the plugin:
* If it's a third-party plugin, report it on the GitHub Issue
* If it's an official plugin, report here
* Make sure you are using the latest version of the plugin. You can update it with `ipm update`.
### Environment <!-- DO NOT IGNORE -->
- Platform: <!-- macOS/Windows/Ubuntu/iOS/Android -->
- Platform version: <!-- Sonoma/11/20.04 -->
- App Version: <!-- Make sure you are using the LATEST version: https://forum.inkdrop.app/c/announcements/ -->
### How to reproduce
<!-- Write the steps for others to reproduce issue here. -->
