During export as PDF, sometimes both the images are exported properly, sometimes the darker image is partially rendered.
Platform: macOS Mojave
Platform version: 10.14.3
App Version: (3.22.4)
Paste the below markdown as a note and try to save as PDF. If you try to export as PDF three times, in one of the saves the second image is not exported properly.
# Sometimes both the images are exported sometimes the darker image is partially rendered
Next are two images. You should open each one in your browser, copy them and paste through clipboard.
the image doesn't appear properly.
https://www.wired.com/images_blogs/wiredscience/2009/11/seti_code.jpg
https://www.google.com/search?q=code+image&rlz=1C5CHFA_enIN795IN796&tbm=isch&source=iu&ictx=1&fir=OB13vciDQObGxM%253A%252CAerQudgyuD2wXM%252C_&vet=1&usg=AI4_-kStxMnbsM0V7F_WXMX3SRFT55aJuw&sa=X&ved=2ahUKEwjfyuaekpLhAhXTEHIKHT4aDeMQ9QEwAHoECAcQBA#imgrc=gEP6nTODYBsoRM:&vet=1
## When I export this note as a PDF, first image appears properly, but the second darker image is not rendered properly
Thank you for reporting.
It seems that the app tries to convert html into pdf before finishing loading images in the internal webview.
It will be solved as I’ve fixed it in the new version of the desktop app.
For now, please export the note as html.
Thanks again!
I see a similar issue. Markdown preview shows pictures correctly but if I export documents to PDF then I see only upper half of pictures. Any idea to fix it? Thank you.
Kazutaka
I can’t promise when it will be out at the moment but i’m working hard on it right now.
You can check my twitter account to see the development progress here.
Works for mi the latest release and fixed the pdf generation, but right now I’m trying to generate another PDF and its cutting part of the images; right now I’m in version 4.6.0.
