Error when using two extensions. Chartjs and Markmap
Hello everyone. I am a new user of this amazing application.
Can you please tell me what I have to do so that the code blocks can be rendered to make graphs with chartjs, when trying to see a graph I get the following error.
And when installing Markmap now I get this error every time I open the app.
I appreciate your comments.
Hi @piloto99 and welcome to the community, in recent versions of Inkdrop “prop-types” was removed and any plugins using it will break. See here: `prop-types` has been removed in v5.5.3 · Issue #11 · jmerle/inkdrop-plantuml · GitHub
The only two ways to fix this are to either downgrade your Inkdrop version or wait for the plugin to be updated to continue using it. A good start would be to contact the author of the package and ping them about the prop-types change.
As for the first error I am not sure, @Lukas or @craftzdog could provide more light on that.
chartjs is created by @elpnt
I guess the error is caused by react-resize-aware.
markmap is created by @John_Kelley
As @NotApplicable mentioned, it can be easily fixed just by removing the dep on prop-types.
It was for improving the app launch speed.
Could you guys look into it?
@piloto99 @craftzdog thanks for your report.
I patched my Chart.js plugin v1.3.5 and it might work well.
If you still have the issue please inform me on this thread or the plugin repository(GitHub - elpnt/inkdrop-chartjs: Inkdrop plugin for Chart.js)
@elpnt Whoa, that was quick! Thank you so much for fixing this!
Thanks for that update. It’s working wonderfully. :+1:
