- Platform: macOS
- Platform version: High Sierra 10.13.6
- App Version: 3.23.1
Install the plugin:
➜ ~ ipm install flowchart
Installing flowchart to /Users/kork/Library/Application Support/inkdrop/packages ✓
Restart inkdrop. Then create a new note with these contents:
```flowchart
start=>end
Then on the preview side this error message appears:
Failed to render Markdown
The error thrown by a plugin: flowchart
TypeError: Cannot read property 'key' of null
at getDisplaySymbol (/Users/kork/Library/Application Support/inkdrop/packages/flowchart/node_modules/flowchart.js/src/flowchart.parse.js:29:26)
at constructChart (/Users/kork/Library/Application Support/inkdrop/packages/flowchart/node_modules/flowchart.js/src/flowchart.parse.js:63:24)
at Object.drawSVG (/Users/kork/Library/Application Support/inkdrop/packages/flowchart/node_modules/flowchart.js/src/flowchart.parse.js:116:9)
at Flowchart.renderDiagram (/Users/kork/Library/Application Support/inkdrop/packages/flowchart/lib/index.js:25:13)
at Flowchart.componentDidMount (/Users/kork/Library/Application Support/inkdrop/packages/flowchart/lib/index.js:13:10)
at CallbackQueue.notifyAll (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/CallbackQueue.js:65:22)
at ReactReconcileTransaction.close (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactReconcileTransaction.js:81:26)
at ReactReconcileTransaction.closeAll (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/Transaction.js:202:25)
at ReactReconcileTransaction.perform (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/Transaction.js:149:16)
at ReactUpdatesFlushTransaction.perform (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/Transaction.js:136:20)
at ReactUpdatesFlushTransaction.perform (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactUpdates.js:86:38)
at Object.flushBatchedUpdates (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactUpdates.js:147:19)
at ReactDefaultBatchingStrategyTransaction.closeAll (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/Transaction.js:202:25)
at ReactDefaultBatchingStrategyTransaction.perform (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/Transaction.js:149:16)
at Object.batchedUpdates (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactDefaultBatchingStrategy.js:62:19)
at Object.enqueueUpdate (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactUpdates.js:176:22)
at enqueueUpdate (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactUpdateQueue.js:24:16)
at Object.enqueueSetState (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactUpdateQueue.js:190:5)
at Constructor.ReactComponent.setState (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/react/lib/ReactComponent.js:65:16)
at Constructor.onChange (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/alt-utils/lib/connectToStores.js:101:14)
at /Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/transmitter/dist/transmitter.js:34:50
at Array.forEach (native)
at Object.publish (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/transmitter/dist/transmitter.js:33:21)
at emitChange (file:///Applications/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:181055)
at Object.dispatchToken.e.dispatcher.register.e [as ID_5] (file:///Applications/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:181638)
at Dispatcher._invokeCallback (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/flux/lib/Dispatcher.js:198:24)
at Dispatcher.dispatch (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/flux/lib/Dispatcher.js:174:14)
at batchingFunction (file:///Applications/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:174395)
at e.batchingFunction.e.batchingFunction.e [as batchingFunction] (file:///Applications/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:173884)
at e.dispatch (file:///Applications/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:174083)
at c (file:///Applications/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:185429)
at Object.u [as renderSuccess] (file:///Applications/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:185562)
at file:///Applications/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:65011
at <anonymous>
