Error dialogs appear when I open the main window. I attached the screenshot.
- Platform: macOS
- Platform version: Sierra 10.12.6
- App Version: (3.14.0)
It happens every time when I open the main window.
Thank you for the report.
Weird. Looking into it.
Could you try this binary?
https://d3ip0rje8grhnl.cloudfront.net/v3.14.0/Inkdrop-3.14.0-Mac.zip
I tried it but nothing has changed
. Same errors appered.
I rebuilt the binary and it is working on my mac.
Actually it’s the same content but the version number has been updated.
Could you try it again?
https://d3ip0rje8grhnl.cloudfront.net/v3.14.1/Inkdrop-3.14.1-Mac.zip
If you are still getting errors, please tell me the error details output to the developer console.
@anon81415781 is it resolved?
@craftzdog It still happen. I pasted the log of the first error I reported before.
/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/debug/src/debug.js:115 Notification: Failed to load the export-all package Object
debug @ /Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/debug/src/debug.js:115
/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/debug/src/debug.js:115 Error: Cannot find module 'core-js/library/fn/get-iterator'
at Module._resolveFilename (module.js:470:15)
at Function.Module._resolveFilename (/Applications/Inkdrop.app/Contents/Resources/electron.asar/common/reset-search-paths.js:35:12)
at Function.Module._load (module.js:418:25)
at Module.require (module.js:498:17)
at require (internal/module.js:20:19)
at Object.<anonymous> (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/babel-runtime/core-js/get-iterator.js:1:186)
at Object.<anonymous> (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/babel-runtime/core-js/get-iterator.js:2:3)
at Module._compile (module.js:571:32)
at Object.value [as .js] (file:///Applications/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:288517)
at Module.load (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/coffee-script/lib/coffee-script/register.js:45:36)
at tryModuleLoad (module.js:447:12)
at Function.Module._load (module.js:439:3)
at Object.<anonymous> (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/babel-core/lib/transformation/file/index.js:6:21)
at Object.<anonymous> (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/babel-core/lib/transformation/file/index.js:738:3)
at Object.<anonymous> (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/babel-core/lib/api/node.js:6:13)
at Object.<anonymous> (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/babel-core/lib/api/node.js:154:3)
at Object.<anonymous> (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/babel-core/index.js:1:173)
at Object.<anonymous> (/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/babel-core/index.js:3:3)
at Object.<anonymous> (file:///Applications/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:289589)
at t (file:///Applications/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:115)
at Object.t.compile (file:///Applications/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:289422)
at n (file:///Applications/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:286328)
at Object.value [as .js] (file:///Applications/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:288499)
at e.exports.e.requireMainModule (file:///Applications/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:88401)
at file:///Applications/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:77339
at e.exports.e.measure (file:///Applications/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:76868)
at e.exports.e.load (file:///Applications/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:77039)
at e.exports.e.loadPackage (file:///Applications/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:194036)
at e.exports.e.loadPackages (file:///Applications/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:193006)
at r.initialize (file:///Applications/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:143853)
at l.default.defer (file:///Applications/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:142085)
at /Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/lodash/lodash.js:2761:43
/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/debug/src/debug.js:115 Notification: Failed to load the export-as-html package Object
/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/debug/src/debug.js:115 TypeError: i.transform is not a function
at Object.t.compile (file:///Applications/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:289483)
at Object.value [as .es6] (file:///Applications/Inkdrop.app/Contents/Resources/app.asar/browser-main.js:1:288499)
at Object.<anonymous> (/Applications/Inkdrop.app/Contents/Resources/app.asar/packages/export-as-html/node_modules/inkdrop-export-utils/lib/index.js:11:16)
at Object.<anonymous> (/Applications/Inkdrop.app/Contents/Resources/app.asar/packages/export-as-html/node_modules/inkdrop-export-utils/lib/index.js:60:3)
at Object.<anonymous> (/Applications/Inkdrop.app/Contents/Resources/app.asar/packages/export-as-html/index.js:4:21)
at Object.<anonymous> (/Applications/Inkdrop.app/Contents/Resources/app.asar/packages/export-as-html/index.js:54:3)
/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/debug/src/debug.js:115 Notification: Failed to load the export-print package Object
at Object.<anonymous> (/Applications/Inkdrop.app/Contents/Resources/app.asar/packages/export-print/node_modules/inkdrop-export-utils/lib/index.js:11:16)
at Object.<anonymous> (/Applications/Inkdrop.app/Contents/Resources/app.asar/packages/export-print/node_modules/inkdrop-export-utils/lib/index.js:60:3)
at Object.<anonymous> (/Applications/Inkdrop.app/Contents/Resources/app.asar/packages/export-print/index.js:4:21)
at Object.<anonymous> (/Applications/Inkdrop.app/Contents/Resources/app.asar/packages/export-print/index.js:101:3)
/Applications/Inkdrop.app/Contents/Resources/app.asar/node_modules/debug/src/debug.js:115 Notification: Failed to load the import-html package Object
at Object.<anonymous> (/Applications/Inkdrop.app/Contents/Resources/app.asar/packages/import-html/lib/select-book-dialog.js:7:16)
at Object.<anonymous> (/Applications/Inkdrop.app/Contents/Resources/app.asar/packages/import-html/lib/select-book-dialog.js:115:3)
at Object.<anonymous> (/Applications/Inkdrop.app/Contents/Resources/app.asar/packages/import-html/lib/index.js:3:25)
at Object.<anonymous> (/Applications/Inkdrop.app/Contents/Resources/app.asar/packages/import-html/lib/index.js:20:3)
It seems like you are still using old version because the file at core-js/library/fn/get-iterator is included in the latest binary.
Please update the app.
I removed old Inkdrop.app and copied new one of version 3.14.1. It fixed errors. Thanks for your help !
Good to hear that.
Sorry for the inconvenience and thanks for your patience!
I have the same problem with the beta version
plugins that I am getting warning.
Also I checked the plugins:
That’s because they are not official plugins and have not updated for the beta yet.
Please contact the plugin authors.
Thanks for response Takuya, I am trying to note anything for the new version
