emoji plugin doesn’t work. I’ve already successfully installed that plugin, I can see it from file-setting-plugin
and I restart the Inkdrop and test it, it doesn’t work.
Platform: windows
Platform version: 10
App Version: (3.25.4)
May 9, 2019, 1:49am
Hi Kevin,
Thank you for reporting it.
That’s weird.
I would like to know following information:
What version of markdown-emoji
have you installed? You can check it with ipm ls
command.
Did you reload the app?
Are there any errors you got in Developer Tools?
May 9, 2019, 8:34am
Thanks for the information.
markdown-emoji@1.0.0
is not compatible with Inkdrop v3.25.4 since it is built for v4 which is currently in beta.
Could you please try the old version like so?
ipm install markdown-emoji@0.3.1
Hope that works.
May 9, 2019, 8:45am
5
I found that markdown-emoji
has an invalid engine
field which should be engines
in its package.json
. I will fix it. Thanks!
Cool, that works, thanks a lot.
