Does it need a real HTTPS certificate to sync with my own compatible server?
After dozens of troubles on sync with Inkdrop’s own service behind Chinese firewall, I decided to set up my own sync server.
I have read the doc Synchronizing in the Cloud and finished my own settings.
But I get a tricky problem that I dont have a real HTTPS certificate , when I run network diagnosis, there is an error like this:
request to https://%my_server%/my-inkdrop-notes/ failed, reason: self signed certificate
So I could not sync between my PC and Android device.
What can I do ?
Could you let sync on mobile via just HTTP ?
Thank you
Hi Joe,
No, it’s highly discouraged to use HTTP for syncing.
Instead, you could use Let’s Encrypt for free SSL certs:
Hope that helps.
It works! Thank you!
