At the top, beside āNotesā it says 141 notes. Below that in the status section it doesnāt show numbers that can add up to ā141ā. Suggestion, add a āNoneā category in there to list the ones without status, so the match can line up?
It feels like Iāve asked this before, but is there a view in this detail section where I can see ALL of the notes no matter what the status is? Currently, if I mark something completed for example, then the only way I can see that note is going to completed. I canāt see it in context ever. Just curious!
Thank you for the question.
The number of āNotesā item indicates number of all notes in a notebook except for notes with Completed & Dropped status. Because āNotesā does not list them.
In your case, I guess you have two notes without status.
You can see them by searching with "status:none" condition.
Yeah it looks sort of weird actually though, I think having a āNoneā category is kind of redundant perhaps.
I need to know what other people think about it.
The behavior of hiding āCompletedā & āDroppedā notes is hard-coded since the first version as I prefer not seeing notes that are done, like todo apps.
I understand your need but Iām afraid that it is hard to change by design.
