Copy inline code :(
Could we bring back the option to copy inline code?
Hi! Previously, with the plugin enabled, I could wrap a word or code in backticks (`) and copy just that content from the preview while keeping it within the same sentence. For example:
The code is copy this.
This was really useful because I also use Inkdrop for work documentation, where I include codes that other people need to copy. It let me keep the explanation and the code together in a clear, compact way. :slightly_smiling_face:
In the new version, I can no longer find this feature. I can use a code block, but it takes up a separate space and breaks the flow of the paragraph. Selecting the text manually is also an option, though I found the previous feature more convenient and visually appealing.
Would it be possible to bring back the option to copy just the contents of inline code without having to turn it into a code block?
Thanks! :slightly_smiling_face:
Hi @eflores ,
Thanks for the suggestion.
Yes, that makes sense. I’ll add a copy button to inline code blocks as well!
it will look like this
It’s been supported in v6.3.0! Thanks again for the feedback
