Copy Image from Right-Click Menu Doesn’t Work @ 5.11.2
When I select “Copy Image” from the right-click menu on an image, it doesn’t get copied to the clipboard. The “Copy Image” option doesn’t work in either edit mode or preview mode.
console.log
browser-main.js:2 Uncaught (in promise) Error: Could not call remote method 'get'. Check that the method signature is correct. Underlying error: Error: Invalid document IDUnderlying stack: Error: Invalid document ID
    at F.validateDocId (/Applications/Inkdrop.app/Contents/Resources/app.asar/main-195.js:2:19887)
    at F.get (/Applications/Inkdrop.app/Contents/Resources/app.asar/main-195.js:2:20068)
    at /Applications/Inkdrop.app/Contents/Resources/app.asar/main.js:2:369048
    at IpcMainImpl.<anonymous> (/Applications/Inkdrop.app/Contents/Resources/app.asar/main.js:2:365579)
    at IpcMainImpl.emit (node:events:519:28)
    at WebContents.<anonymous> (node:electron/js2c/browser_init:2:84486)
    at WebContents.emit (node:events:519:28)
    at /Applications/Inkdrop.app/Contents/Resources/app.asar/main.js:2:369076
    at WebContents.emit (node:events:519:28)Caused by: Error: Invalid document ID
  • Platform: macOS 14.7.1(23H222) / Windows 10
  • App Version: 5.11.2
Hi shimizu-san,
Thanks, will fix it in the next release! This was due to an API deprecation in Electron.
@shimizu_tatsuya Can you please try this patch?
I was able to copy the image.
It’s working now.
Thank you!
I had the same problem and the patch worked, thanks!
Thanks for checking it, @shimizu_tatsuya @Ondrej_Malik !
I’ve released v5.11.3 :smile:
Cheers
