Commands for Changing Note Status
(Hiroaki Ogasawara) #1
What I want
I want to make original key binding. Especially, I want to switch notes status by keybindings.
So what is command for switching status?
I tried
Find command lists in documentation, but not found.
https://doc.inkdrop.info/manual/customizing-keybindings
(Takuya Matsuyama) #2
Hi hiroga-san,
In terms of implementation, I’m afraid that it is not possible to get a full list of commands because commands are bound with target DOMs.
At the moment, commands for changing note status are not available.
Those commands would be nice to have so I’ll plan to add them.
(Hiroaki Ogasawara) #3
Hi craftdog san.
Thank you for explanation. I`m looking forward InkDrop will be added the command.
Thank you for develop the best editor.
(Takuya Matsuyama) #4
Now v3.23.0 added commands for changing note state:
  • editor:change-note-status-none
  • editor:change-note-status-active
  • editor:change-note-status-onhold
  • editor:change-note-status-completed
  • editor:change-note-status-dropped
changelog: https://doc.inkdrop.info/releases#v3-23-0
Thanks again for the suggestion!
