cannot check/uncheck “Task List” items
in any note, click the Task List button, now try and check the checkbox… nothing happens
I just tested on android (5.1.1.) and it works correctly there. must be a breaking change to the debian version?
Hi Scott,
Thank you for reporting it.
I confirmed that’s a bug. Will fix it!
Fixed in v4.3.2. Thanks for reporting!
I didn’t have a chance to apply the patch, but the update to 4.3.2 (on debian/amd64) has fixed the issue.
Thanks
