When you use checkboxes and not fill something immidiately behind it on the same line, for example a line with just a textbox, then the text that is suppose to be on the next line in merged with the checkbox line in the preview.
An example of this can be seen on the screenshot below, this also happens with titles.
Yeah, it’s actually an invalid Markdown syntax but the issue could be avoided with CSS.
I’ll fix it in the next release. As a workaround, add the following CSS in your styles.less for now:
