When creating a numbered list with a checkbox, containing a sublist with checkboxes, the checkbox overlays the number on the parent item of the sublist.
E.g. -
Pasting the following in to Inkdrop:
1. [ ] a
1. [ ] b
Renders as:
(Dark Theme)
(Light Theme)
Expected behavior:
a
i. b
Platform: Windows
Platform version: Enterprise, Version 10.0.17134 Build 17134
Thank you for the report.
First, ordered list with checkbox is not a standard feature in GitHub-Flavored Markdown.
Seems like remark, which is a Markdown processor library the app uses, parses it as you expect but my rendering module does not support it.
So basically I don’t recommend you to use it as I would follow GFM’s specifications.
