I Have an Error Where if I try to use the backticks ``
and preview the markdown this Error Appears
Failed to render Markdown
Cannot read properties of null (reading 'useState')
- Platform: windows 11
- Inkdrop Version :5.5.3
I guess one of the plugins you installed is causing the issue.
Which plugins have you installed?
Yes you are correct the plugin that was causing the problem is copy-code-to-clipboard
Thank You
Great App By The way
