Can't snap Inkdrop to left/right of display
When I attempt to snap the Inkdrop window to the left or right of my display it not only does not snap but it also causes the Inkdrop window to “shake”, causing every other window to minimize. The windows minimizing due to a shaken window is normal, but it’s happening unintentionally. Additionally, since Inkdrop doesn’t snap, it gets placed partially off-screen and the response is extremely slow when I drag it back to view.
Edit: Wanted to clarify that it does snap to the top, full-screen, as long as it’s not shaky.
inkdrop
Troubleshooting:
  • :check_mark: relaunched Inkdrop
  • :check_mark: verified Inkdrop was the only window/app affected
  • :check_mark: Network Diagnosis
  • :check_mark: machine reboot
  • Platform: Windows
  • Platform version: 10.0.19045
  • App Version: 5.5.3
  1. Open Inkdrop
  2. Drag window to left/right side of display
  3. Drag window back to view
Hi Dragon,
That’s weird. I tried to reproduce it on my Windows 10 machine but couldn’t.
The app properly snaps to the left and right of the display by dragging.
It didn’t cancel snapping like your video.
It doesn’t have any features that would affect snapping.
So, I don’t know what’s causing the issue at the moment.
Hello Takuya,
No worries, it’s not the biggest issue and I’m still enjoying Inkdrop! It’s an amazing tool and I’m slowly making the transition over from Obsidian. Once the issue is cleared, I’ll add any info I have about it here. Take care!
