Can I use Inkdrop offline?
Could Inkdrop be used locally and sync to the cloud later when I have access to the internet?
Even though there’s internet almost everywhere but just in case if the internet crashes or I came by a place with no internet access would I still be able to use inkdrop and sync my notes later?
Hi Richard,
Thanks for the question.
Yes, Inkdrop is designed to be offline-first.
Once you are back online, it resumes syncing notes.
A login session is valid for 30 days without an internet connection.
Sorry for the late reply. Thank you so much, I have also tested the offline situation my self and I am so please with the results, Inkdrop is just a app that is too good to be true. Thank you for all your hard work.
Cool! Thanks, Richard
