Hi there, I’m new to Inkdrop! I’m wondering that if by any chance Inkdrop supports internal links among notes? To be more specific, I’m wondering if I can put a link as reference to a note I wrote before inside the note I’m currently working on.
On top of this (if Inkdrop does support a way to do this), can Inkdrop make sure that the link ALWAYS works even if I move the referred note to somewhere else (changing its parent notebook).
This is really important for me because I wish to build a interrelated knowledge space with a MD note taking app and I can re-organize it freely without breaking the relationships of the pages.
p.s. I deleted the template for bug report because I guess this is nothing to do with bug, but the prompt under “feature” tag says that I should post with “support” tag if I’m not sure the feature exists or not.
