[Beta 5.0.0(29)] Embed plugin not working
Hello Takuya,
How can I access a markdown renderer to toggle on/off of each plugin on this beta version? The production version usually appears under advanced setting menu.
Thank you,
Bundit
Hi Bundit,
Thanks for the question.
The Markdown syntax extensions like Mermaid are not possible to be toggled in the new version.
Which feature would you like to disable, particularly, and why?
I just would need to find out why my embed plugin doesn’t work like existing production v4.2.4(103) and then try to find a setting to toggle this on.
Thank you,
Bundit
The embed plugin is not added yet.
It is planned to be implemented!
That’d be nice to bring about this feature again.
Thank you,
Bundit
yeah I want it, too
It is fixed in v0.2.2. Thanks a lot.
