Behavior After Executing the 'zt' Command in inkdrop-vim's Normal Mode
I always appreciate using Inkdrop.
I would like to inquire about the subject matter.
In normal mode, after typing ‘zt’ and then moving the cursor with the space key or similar, it appears that the screen shifts. Is this the intended behavior?
Platform: macOS
Platform version: Ventura 13.5.1
App Version: 5.5.3 (5.5.3)
inkdrop-vim: 2.2.2
Thank you in advance for your guidance.
Best regards,
Inkdrop
Inkdrop
Vim
Vim
VScode(Visual Studio Code)
VScode
Hi Tsukamoto-san,
Thanks for the question.
It looks like the behavior is due to the Cursor Scroll Margin setting:
You can set it to 1 to reduce the margin to avoid the unexpected scroll.
Hi Takuya-san,
Thank you very much for your prompt and detailed response.
After setting the Cursor Scroll Margin to 1, the issue was successfully resolved.
Thank you again for your assistance.
good to know it helped! enjoy
