I know I’m not even a premium user of your app to suggest anything, but… if you could at least think about the suggestion of a user of the demo version
of your app:
I often use to mark some keywords, especially those that refer to some special “context” like variables or functions like this:
Game,Peanut(),sayMeow(), the problem is that when I select a word and press the backtick button, the word is removed and only the backtick is inserted. To solve this, I cut the word, insert the backtick and paste the word inside. It would be nice if when I select a word and press the button, the word was not removed.
My monitor is kind of small, so it’s a bit complicated to use the “side by side” view. Would it be possible to have a markdown view, but editable? Or does this already exist?
A problem that I have from time to time is when selecting lines that are close to the top edge of the screen, when I select these lines and drag the cursor slightly upwards, the page scrolls abruptly.
