Anchor support for note links
You can currently create links to other notes using the [](inkdrop://note/id) syntax.
You can also create links to specific headers within notes using the [](#header-id) syntax.
I think it would be really neat to be able to link from one note the a specific header in another note using a syntax like [](inkdrop://note/id#header-id)
Hi MHBrunbjerg,
That’d be nice to have.
It should be easy when the editor is in preview mode.
In edit mode, it should also scroll to the specified heading.
To accomplish that, the app has to store the positions of the headings when parsing the Markdown.
It’ll be considered after the current roadmap is finished.
