Add a button for copying code to clipboard to code blocks on preview
Hi Takuya
It would be great if you can implement a button in every code block (preview view) to copy the content of the code block into the clipboard. Maybe a copy icon in the top right corner of the block? This is relevant for the Desktop app version. I have many PowerShell code snippets documented which I use periodically.
Thanks.
Hi Claudio,
Copy button sounds useful.
However, I guess it would be a personal preference because it may be distractive for some people since it is basically a note-taking app.
So it would be great if it’s a plugin.
Your plugin submission will be appreciated!
Hi , I have been looking into this, but was wondering how I could get the code context
I have seen other examples of people doing this such as ,
https://codepen.io/vvo/pen/ZLvXdb
https://stackoverflow.com/questions/9492842/does-codemirror-provide-cut-copy-and-paste-api
but it seems I would need to get the code context from the main editor in inkdrop.
Is this possible through sifting through the body or should it be connected to the class gfm-codeblock-bg?
Would love some advice on how to make the plugin
There’s already the copy-code-to-clipboard plugin for this.
Ah, was looking for some low hanging fruit that I could maybe contribute.
Thanks for the heads up!
That’s a plugin made by a user Takamitsu-san.
Thanks for considering to make a plugin, @anon18815998 :wink:
And thanks for letting him know, Jasper!
Hello @craftzdog. Said plugin does not seem to work for Canary v6.
Are there plans to get it to work again, I really need it for work.
Maybe it should be built in so it can work both in edit and preview mode.
@anon33229191 Yes: The Roadmap of Inkdrop vol.6
