Today I used Inkdrop in windows 10. I placed the Inkdrop window on the external screen in my office. Later I returned home, I couldnāt open the app properly. It was always staying off the screen. I tried shift + right click the icon in task bar to move it, but it didnāt work. The only way is to maximize it, then to resize.
Thank you for the report.
You can bring the window back with arrow keys after selecting move menu on task bar.
Also you can fix the saved position in C:\Users\<USER>\AppData\Roaming\inkdrop\config.cson like so:
Thanks for the tip. Yesterday I really felt frustrated when I couldnāt reach my notes. Inkdrop has become an important part of my workflow. Thanks for your effort to keep making it better.
I also had this issue. The app lands in the middle of the two screens, seems to be treating them as one. Can this be fixed so it defaults to the primary monitor?
