Is it possible to insert a timestamp (ideally with keyboard shortcut) when writing in markdown?
Hi Johannes,
Thank you for the question.
Yes, you can do that by adding custom script:
const moment = require('electron').remote.require('moment')
inkdrop.commands.add(document.body, {
'custom:insert-date': () => {
moment.locale('en');
const cm = inkdrop.getActiveEditor().cm;
cm.replaceSelection(moment().format('LLLL') + "\n");
inkdrop.menu.add([
"label": "Format",
"submenu": [
{ "label": "Insert Date", "command": "custom:insert-date" }
And bind a command custom:insert-date
with preferred keystroke by setting keybindings like so:
'body':
'shift-ctrl-k': 'custom:insert-date'
thanks a lot for your prompt reply. It works perfectly
All the best,
Johannes
