Yeah, it’s kind of annoying when you are on a new PC.
However, CouchDB’s replication protocol only lets you sync in chronological order.
I’ll plan to support it when I find a way to solve that.
Yes, because CouchDB & PouchDB’s sync protocol is reliable. Decoupling would solve that but causes a lot of breaking changes in the core modules. Let me look for another solution.
