File open dialog not showing when importing note from HTML
I’m trying to import my notes from Evernote.
I download them in HTML and then try to import them in Inkdrop:
Select ā€˜Inkdrop -> Import -> from HTML files…’ from menu.
But after selecting the target notebook and clicking Ok nothing happens.
The note is not imported and I don’t get any error message.
Console logs:
  • Platform: (macOS)
  • Platform version: (High Sierra 10.13.5)
  • App Version: (3.20.1)
  1. Export note from Evernote in HTML.
  2. Select ā€˜Inkdrop -> Import -> from HTML files…’
  3. Select target notebook
  4. Click Ok
    –> Nothing happens
Thanks.
Hi David,
Thank you for the report.
I tried to reproduce it but couldn’t. It works as expected on my mac (10.13.5). That’s weird.
After clicking OK button, the app will show a file open dialog but it fails for some reason.
At the moment, I’m afraid that I don’t understand why it doesn’t work because you don’t get any error message.
I’d like to know if this problem occurs on other users’ machines.
