Lukas
After i updated to canary.20 i get an error that the default syntax theme is not installed. I cannot select it in the theme picker.
- Platform: Windows
- Platform version: 11
- App Version: 6.0.0-canary.20
- Install Inkdrop v6.0.0-canary.20
- Open the settings & select the “Themes” tab
- Observe that the default syntax theme is missing
Hi @Lukas ,
I think it is my mistake when building the windows binary.
I’ll rebuild it later soon.
Rebuilt the windows binaries. Can you try it?
Lukas
Fixed. The default-syntax theme is now available as expected.
