Thank you for reporting it.
Thatās weird. I need to reproduce it in order to solve it.
Can you please tell me what kind of device you are using and its Android version?
Hmm, as you can see your notebooks synced, I guess itās not a sync problem.
Does it also not work if you switched a notebook from side menu?
How about search?
I need to reproduce it but canāt at the moment.
Iāve got an error log from the beta app which is:
URIError Ā· String contained an illegal UTF-16 sequence.
This is happening while processing a particular note with encodeURIComponent to calculate MD5 digest.
I will try to reproduce it.
Do you have any idea on it? Something like youāve wrote special characters in your notes.
Thank you for your cooperation!
