Hi, I set up my API key from the Claude API, but it seems the AI integrations don’t work here. Maybe I missed something?
- Platform: macOS
- Platform version: 15.8.1
- App Version: 6.1.5
You will need to hit Enter after entering the api key into the text box. Then a green checkmark should appear next to “Anthropic” to let you know that the provider is ready to go.
Oh yeah, press Enter, my bad. Now it works, thanks.
